How to get image size of COP2 node?
I need to know the size of the COP2 node for some input node. I can get a sequence info (TIL_Sequence) by calling getSequenceInfo member function of COP2_Node class. But it has only resolution info (getRes function), which is a visible size of the image, not an actual size.
Edited by Quantico
OK. Thanks for your reply.
So to get the image actual size you need to write the following code:
int x, y, x1, y1, x2, y2;
float tm = some_node->getSequenceTime(); // ???
TIL_Sequence * seq = some_node->getSequenceInfo();
TIL_Plane plane(*seq->getPlane(some_node->getColorPlaneName()));
plane.setFormat(PXL_FLOAT32);
seq->getRes(x, y);
some_node->getImageBounds(&plane, 0, tm, x, y, 0, x1, y1, x2, y2);
Right?
float tm = context.getTime();
Right. Or, if you have a COP2_Context in cookMyTile(), you can pass that instead of { plane, 0, tm, x,y, 0 } using the second getImageBounds() signature - If you just want the image size of the plane you're processing (or the size of the input plane). If you need to access a different plane, you need the longhand version.
