celd Posted April 25, 2019 Share Posted April 25, 2019 Hi, I am trying to get a list of all the extensions that file sop can read/write, for example: bgeo.sc, vdb, abc, etc - with python. Is there a way to load them all into an array without writing it manually one by one? Thanks Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 26, 2019 Share Posted April 26, 2019 I don't know reliable future-proof way to get the exact list of geometry files for File node. 1. To make hou.ui.selectFile() ask for geometry, pass file_type=hou.fileType.Geometry parameter. 2. You can parse data from "$HH/GEOfiles" and "$HH/GEOio.json", which appear to provide most common geometry formats. 3. To get the most extensive list of supported geometry, I'd parse the help message of gconvert utility: import re import subprocess formats = {'Read': set(), 'Write': set()} # Capture output of gconvert utility. path = 'gconvert' try: out = subprocess.check_output(path, shell=True, stderr=subprocess.STDOUT) except: pass # Split output into major pieces. _, builtin, _, external_translators = re.split(r'-- Built-In --|-- Translators --|-- External Translators --', out) # Parse "Built-In" piece builtin = set(builtin.partition('Recognized Extensions:')[2].replace(',', '').split()) formats['Read'] |= builtin formats['Write'] |= builtin # Parse "External Translators" piece external_translators = re.findall(r'\((Read)-(?:Only|(Write))\)\n.*: ([\w., ]+)', external_translators) for read, write, extensions in external_translators: extensions = set(extensions.split(', ')) if read: formats['Read'] |= extensions if write: formats['Write'] |= extensions # Manually add 2 formats from "Translators" piece and also add FBX read. formats['Read'] |= {'.hgt', '.fbx', '.vdb'} formats['Write'] |= {'.vdb'} It will output this: {'Read': {'.abc', '.ai', '.bgeo', '.bgeo.bz2', '.bgeo.gz', '.bgeo.lzma', '.bgeo.sc', '.bgeogz', '.bgeosc', '.bhclassic', '.bhclassic.bz2', '.bhclassic.gz', '.bhclassic.lzma', '.bhclassic.sc', '.bhclassicgz', '.bhclassicsc', '.bjson', '.bjson.gz', '.bjson.sc', '.bjsongz', '.bjsonsc', '.bstl', '.dxf', '.eps', '.fbx', '.geo', '.geo.bz2', '.geo.gz', '.geo.lzma', '.geo.sc', '.geogz', '.geosc', '.hbclassic', '.hbclassic.gz', '.hbclassic.sc', '.hbclassicgz', '.hbclassicsc', '.hclassic', '.hclassic.bz2', '.hclassic.gz', '.hclassic.lzma', '.hclassic.sc', '.hclassicgz', '.hclassicsc', '.hgt', '.iges', '.igs', '.json', '.json.gz', '.json.sc', '.jsongz', '.jsonsc', '.lw', '.lwo', '.obj', '.off', '.pc', '.pdb', '.ply', '.pmap', '.stl', '.vdb'}, 'Write': {'.abc', '.bgeo', '.bgeo.bz2', '.bgeo.gz', '.bgeo.lzma', '.bgeo.sc', '.bgeogz', '.bgeosc', '.bhclassic', '.bhclassic.bz2', '.bhclassic.gz', '.bhclassic.lzma', '.bhclassic.sc', '.bhclassicgz', '.bhclassicsc', '.bjson', '.bjson.gz', '.bjson.sc', '.bjsongz', '.bjsonsc', '.bstl', '.dxf', '.geo', '.geo.bz2', '.geo.gz', '.geo.lzma', '.geo.sc', '.geogz', '.geosc', '.hbclassic', '.hbclassic.gz', '.hbclassic.sc', '.hbclassicgz', '.hbclassicsc', '.hclassic', '.hclassic.bz2', '.hclassic.gz', '.hclassic.lzma', '.hclassic.sc', '.hclassicgz', '.hclassicsc', '.iges', '.igs', '.json', '.json.gz', '.json.sc', '.jsongz', '.jsonsc', '.lw', '.lwo', '.obj', '.off', '.pc', '.pdb', '.ply', '.pmap', '.stl', '.vdb'}} Difference may not worth it, but it exist: >>> formats['Read'] - formats['Write'] {'.ai', '.eps', '.fbx', '.hgt'} >>> formats['Write'] - formats['Read'] set() 2 Quote Link to comment Share on other sites More sharing options...
celd Posted April 26, 2019 Author Share Posted April 26, 2019 Thanks a lot for this! I tried the python gconvert method and the odd thing is that I cant get it to write the output of subprocess.check_output() into a variable. No matter what I do it errors out into a "CalledProcessError: Command 'gconvert' returned non-zero status 1". I actually managed to get it to write the output into the console by removing the "stderr" flag, but it always ends with an error and does not assign the output into a variable. Do you have any ideas what could be the reason for this/how to get around it? Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 26, 2019 Share Posted April 26, 2019 Hmm, weird that it did work for me earlier. stderr parameter is required to skip console popup (on Windows). Try to catch the subprocess.CalledProcessError exception: try: out = subprocess.check_output(path, shell=True, stderr=subprocess.STDOUT) except subprocess.CalledProcessError, e: out = e.output This now works for me, in clean scene. 1 Quote Link to comment Share on other sites More sharing options...
