VOPs - output to @P.y.
Krion
You could use Set Vector Component VOP to pick a specific component of a vector and set its "fval" to be the output of your ramp. The geometry vop outputs however expect P to be a vector and you will need to give it a vector. I dont think you can export just a specific component directly.
what about something like this? Use get vector component and use component 2 which is Y. You can make as many changes to Y as you want then merge it back. Any changes here would only affect the Y position.
Edited by ejr32123
  • 2 weeks later...
  • 3 weeks later...
