Volume Visualisation Artefacts
Good morning all,
Would like to check with you before I report the bug. is this a normal behavior?
Volume Visualisation has those weird shape in the viewport, which disappears as soon as I pan around the volume, and come back when I play the animation.
Copied the same Vol Vis node and got different shapes.
Newly created node has only 1 small line in the middle:
