Emit Between range (scene attached)
Hi guys, im struggling to achive, this effect:
An particle emission each 20 frames, holding for 3 frames, then cutting emission, after 20 frames repeat the first step.
I came with an expression, but it only holds 1 frame then cut. So the challenge is hold 3 frames instead 1 (scene attached)
thanks.
emit_range.hipnc
