ghenci Posted May 12, 2019 Share Posted May 12, 2019 (edited) Hello to all! Question regarding the vellum and vellumrestblend. I have a number of planes scattered on the surface. I want to rotate them on some degrees in vellum simulatation. So, I put together a super simple setup using the vellumrestblend. Rest planes in SOP rotate as they should. But when I switch to vellum simulation, some of the planes rotate as they should, and some in the opposite direction. What am I doing wrong? Here is some screenshots and hip file. Thanks! grow_plains_Vellum2.hipFetching info... Edited May 12, 2019 by ghenci Quote Link to comment Share on other sites More sharing options...
