Noise on ramp transition (edge)
Hello amazing Houdini people!
I have been struggling with what i thought would be an easy thing to do. (It probably is but my brain cant figure it out)
In the image below you can see a unified noise (static) being multiplied with ramp paramater.
Output becomes then noised ramp.
What i want to achieve is noise ONLY on the edge of the ramp.
Kind of like growth.
Any advice? Losing my mind here :blink: have been using fit and clamps but cant seem to do it.
One thing to note is taht im not actually animating the ramp, im animating the UV coordinates.
  • 2 years later...
Bumping this old thread in case anyone else finds themselves in a similar boat where they're drawing a blank on this technique and end up googling "Houdini noise transition".
The trick is to first form your gradient using a value, in this case the x position along a grid...
...and then add noise to that value.
For a deeper dive into this kind of thing, definitely check out this series of classes by Main Road Post and this brilliant page by Kiryha.
Hope this helps.
  • Like 5
