Neekozo Posted May 18, 2019 Share Posted May 18, 2019 Hello amazing Houdini people! I have been struggling with what i thought would be an easy thing to do. (It probably is but my brain cant figure it out) In the image below you can see a unified noise (static) being multiplied with ramp paramater. Output becomes then noised ramp. What i want to achieve is noise ONLY on the edge of the ramp. Kind of like growth. Any advice? Losing my mind here have been using fit and clamps but cant seem to do it. One thing to note is taht im not actually animating the ramp, im animating the UV coordinates. Quote Link to comment Share on other sites More sharing options...
velurpasha Posted May 18, 2019 Share Posted May 18, 2019 noise_shift_001.hipnc Quote Link to comment Share on other sites More sharing options...
Neekozo Posted May 18, 2019 Author Share Posted May 18, 2019 Wow! Thanks so much! I will pick this apart, BIG thanks Velur!! Quote Link to comment Share on other sites More sharing options...
Neekozo Posted May 20, 2019 Author Share Posted May 20, 2019 Hello again! I was trying out your setup, it works for all intents and purposes. I am just wondering if there are other ways to accomplish this? Quote Link to comment Share on other sites More sharing options...
HundredsofBears Posted October 4, 2021 Share Posted October 4, 2021 Bumping this old thread in case anyone else finds themselves in a similar boat where they're drawing a blank on this technique and end up googling "Houdini noise transition". The trick is to first form your gradient using a value, in this case the x position along a grid... ...and then add noise to that value. For a deeper dive into this kind of thing, definitely check out this series of classes by Main Road Post and this brilliant page by Kiryha. Hope this helps. 4 Quote Link to comment Share on other sites More sharing options...
