question for pcopne() function
Reza82N
Hi guys,
i am new to vex , in this very simple example i have some questions about pcopen() , i would be appreciated if you helped me,
vector origin = point(1,"P",0) // a single point has been connected to first input of the wrangle
int amount = chi("amount");
int radius = chi("radius");
int handle = pcopen(0 ,"P",origin,radius,amount);
if (pcnumfound(handle)>0)
	@Cd = {1,0,0}; ;
as i know for the code above : we have a radius around an origin to search for amount of point(s) connected to 1st input of the wrangle  , then if some points have been found the statement would run for those points
when i am going to translate what i have mentioned in the line above , i can't understand what is happening below ,
int handle = pcopen(1 ,"P",@P,radius,amount); // a single points has been connceted to 2nd input
if(pcnumfound(handle)>0)
      @Cd = {1,0,0};
when i look to geometry spreadsheet , @P is referring to 1st input and the number 1 in pcopen()  is referring to 2nd input ,
we have the origin (center of point cloud) from 1st input which is @P , and we are connecting the pcopen() to 2nd input of the wrangle,
in result  we have a point cloud which it's center is that external point , and the slide "amount" doesn't affects the number of points founded in the point cloud ,
i know i misunderstood something but i couldn't find it.
the project file has been attached.
Scott82N.hipnc
Edited by Reza82N
