Krion Posted May 19, 2019 Share Posted May 19, 2019 (edited) Hi, When I use a Remesh on my mesh, it doesn't do anything. Tried changing any parameter. Anyone has an idea why this is? Was also wondering why I can't choose quadrilaterals in my PolyFill. Help would be appreciated. Edited May 20, 2019 by OdForest Quote Link to comment Share on other sites More sharing options...
davpe Posted May 20, 2019 Share Posted May 20, 2019 hi, 1. PolyFill wouldn't work with quadrilaterals on this particular shape as it wasn't able to produce full quad output due to pointed ends (if you made end tips slightly beveled it would work) 2. can't give you a technical answer why remesh was not working for the shape you produced. anyways, when I built the same shape in a way I would normally do it, it magically started to work. i guess polyFill is not really meant to produce a mesh out of curves, and while it did it, it ended up being an invalid surface in some way. cheers, D. 1 Quote Link to comment Share on other sites More sharing options...
Krion Posted May 20, 2019 Author Share Posted May 20, 2019 Thank you.. Skin would be a better method indeed. Quote Link to comment Share on other sites More sharing options...
