Can't use boolean detect output (ainsideb)
Hi All
I'm trying to use boolean detect ainsideb, on polygon spheres. ainsideb is in output Primitive groups, most of which is greyed out. There's a tick on A inside B in this list but the group doesn't appear in the geometry spreadsheet. The noise that I'm running on this group in the next node doesn't work. However, it does work on axbpolys and if I switch the boolean to Intersect or Subtract they work normally.
Anyone know what the issue is or what I'm doing wrong?
Thanks, Robbie
