fell00 Posted June 17, 2019 Share Posted June 17, 2019 Hello, When I run a simulation the blue bar always starts disappearing from the beginning of the timeline. As a result, I can not scrub all the way through my sim. Is this normal behavior or is there some setting that can be changed? -houdini version 17.5 Quote Link to comment Share on other sites More sharing options...
ikoon Posted June 18, 2019 Share Posted June 18, 2019 Hi fell, on the DOPNET node, increase the Cache Memory limit (MB). Or, if you don't have enough RAM, you can Allow Caching to disk (the simulation is saved to files in the temp directory). More info is here: https://www.sidefx.com/docs/houdini/nodes/obj/dopnet.html Quote Link to comment Share on other sites More sharing options...
fell00 Posted July 2, 2019 Author Share Posted July 2, 2019 Thank you, it works. Now I can scrub the whole sim, very good to know. Quote Link to comment Share on other sites More sharing options...
