LeGalactique Posted June 22, 2019 Share Posted June 22, 2019 (edited) Hi all, I am fairly new to VEX and currently on day 12 of joy of vex, I was trying to do this excercise: "Highlight red all the points where their ptnum can be cleanly divided by 10" Someone recommended to use modulo and I did find a way to make it work but honestly I do not entirely understand why it works, if anyone can help me understand this better I would appreciate it. I understand modulo is basically the remainder of a division and that in this case it will loop from 0,1,2,3,4,5,6,7,8,9,0 through @ptnum. int a = @ptnum % 10 ; if (@ptnum = a) { @Cd.r = 1; } else { @Cd.g = 0; @Cd.b = 0; } Edited June 22, 2019 by LeGalactique Quote Link to comment Share on other sites More sharing options...
flcc Posted June 22, 2019 Share Posted June 22, 2019 2 hours ago, LeGalactique said: I understand modulo is basically the remainder of a division and that in this case it will loop from 0,1,2,3,4,5,6,7,8,9,0 through @ptnum. There, you've perfectly understood what it's for. Creating loops from continuous data is the main use of this function. Quote Link to comment Share on other sites More sharing options...
LeGalactique Posted June 22, 2019 Author Share Posted June 22, 2019 (edited) Hey thanks! So basically when I say: if (@ptnum = a) //I still don't get why this works on my first code. I was doing things backwards? I mean I can use this to tell Houdini that all numbers not 0 will be one color, so I should have written: if (@ptnum != a) That was the part I didn't catch, it is all based on any number that doesn't have a remainder right? Something like: if (@ptnum %10 == 0) { @Cd = {1,0,0}; } Edited June 22, 2019 by LeGalactique Quote Link to comment Share on other sites More sharing options...
flcc Posted June 22, 2019 Share Posted June 22, 2019 All number have a remainder even if its 0. If you want to better understand what happen make "a" an attribute and check the geometry spreadseet, you will see all the values generated. i@a = @ptnum % 10; if(@a == 0) { @Cd = {1,0,0}; } Or you also can use the printf function. Quote Link to comment Share on other sites More sharing options...
LeGalactique Posted June 23, 2019 Author Share Posted June 23, 2019 17 hours ago, flcc said: All number have a remainder even if its 0. If you want to better understand what happen make "a" an attribute and check the geometry spreadseet, you will see all the values generated. i@a = @ptnum % 10; if(@a == 0) { @Cd = {1,0,0}; } Or you also can use the printf function. I had done this before but still wasn't getting it, I appreciate your help alot and I think I understood now entirely. What I didn't get was why if I did (@ptnum = a) then I could color all numbers from 1-9 between each 10th increase. Since I am a beginner I was failing to understand the difference between == equal to and = asign or can be asigned. Also I was thinking of the modulo remainder and failing to grasp how those values translated to houdini, when you just see it as a loop and see that the loop is 1-9 then every tenth is 0 or basically nothing and that cannot be assigned as a value to ptnum hence you can pinpoint that to add a value. This is how I have come to understand it, needed to really know what happened basically. Quote Link to comment Share on other sites More sharing options...
flcc Posted June 23, 2019 Share Posted June 23, 2019 Cool. But I would still suggest you to acquire some programming basics elsewhere, because VEX and the graph system adds a layer. If you are also a beginner in coding, it will be difficult for you to determine the source of errors. There are many sites to learn a language. VEX is close to C, but java, or even python can do the trick to learn coding. Quote Link to comment Share on other sites More sharing options...
LeGalactique Posted June 24, 2019 Author Share Posted June 24, 2019 Ok will do that, thx! Quote Link to comment Share on other sites More sharing options...
