Mutliparm handles to Add Node
broomy
I`m adding any number of points that is specified by the number of entries in a multiparm by referencing the multiparm to an Add nodes "number of points" parameter.
The multiparm is on a subnet/hda and the add node is in the subnet/hda and this is fine as it is only one reference but all the points from the Add node are at 0,0,0.
So the question,
At the subnet/hda level how do I have a Handle for each point that has been added, not going into the subnet and moving the points on the Add node?
Hope this makes sense and any help would be greatly appreciated as I`m totally stuck after a long time of reading and playing with the type properties
Thanks
