Help with arqtiq houLEAP tool
meldrew
Hi all,
I recently found this Toolset on Github allowing realtime input & record of input from a leapmotion controller.
https://github.com/arqtiq/HouLEAP
Unfortunately I'm having a little trouble getting it to run properly.
In the readme it explains to 'simply copy the content of the **/houdini16.x** folder to your houdini home/hsite folder.'
So my question is, where would be the correct place to place the python scripts that the tool provides? (I'm not entirely sure what the 'hsite' folder is referring to?)
Houdini see's the OTL's however i return the attached error in, what i assume, is the python scripting. Or perhaps I need to define LEAP in the .env file?
Any tips much appreciated :)
EDIT: The error is reported from the example .hip contained in the Github repository linked in my post. Also This was run in H 17.5.258.
Edited by meldrew
