inject single particle to flip on event
ino
is there some way to add a defined number of particles to a flip fluid?
a have a pop which generates some particles if this particles meet some criteria i want to add them to a flip
a popsource will add them over and over again i need them just one time.
lets say i have 100 pop particles with a random attribute Q (1..100) if the frame number is the same as Q i want them to be added to the flip
I took a shot at this, threw up a scene to show you what I found to work.
What I have done is,
1. Put the particles I want in flip into a group "particles"
2. Delete the particles the next solve step.
3. Import the pop particles in a sopnet delete everything but the "particles"
4. Use that sopnet for importing to flip.
Hope that helps
pop_to_flip.hiplc
thank you exactly what i was looking for!
where i am stuck now is i cant do it exactly like you and would need to put the points from an existing group to a new one to be deleted
i have put this for testing in the popgroup vex
setpointgroup(0, "XY", @ptnum, 1);
setpointattrib(0, "X", @ptnum, inpointgroup(0, "XY", @ptnum));
in the geosheet X is 0 on all points how can that be when i just put them in 1 line prior!
that they are in group XY is shown correctly in the geosheet
I'm not 100% sure but I don't think you can create groups like that in the POP group node, should work in popwrangle with the input 0 set to myself.
This works in the setup I created, just added another POP group node with this inside.
5d2e6bef0d068_Screenshotfrom2019-07-1702-28-48.png.a452cdd429ed1f7556187d55336ebff9.png
Edited by AslakKS
thank you!
the group creation works just fine like this in a popgroup but it was just ment as a test
what i was missing is how to check if the particle is or isnt in the group
was trying to use  inpointgroup(0, "groupname", @ptnum) which by the documentation should work but does not or i missing something
@group_groupname does the trick
@group_groupname <> inpointgroup(0, "groupname", @ptnum) should by equivalent but one works the other not
just starting so missing a lot of things
