liu_0083 Posted July 8, 2006 Share Posted July 8, 2006 DOP is pretty new to me. What I want to do is just to do a test with 1000 boxes falling down. Do I need to make use of changing the number of copy in DOP RBD object, arranging the formation using expression for position, or can I just build the whole model using copy and then I can apply dynamic to every little boxes inside ? No idea though C. Quote Link to comment Share on other sites More sharing options...
Visual Cortex Lab Posted July 8, 2006 Share Posted July 8, 2006 I'm not a master in DOP but i'm quiet sure you can do both way. in the second way just use RBD fractured object.. and in the SOP create the gorup for each copy so that each box its a group. correct me if i'm wrong cheers Quote Link to comment Share on other sites More sharing options...
