Middle button ladder for multi monitor setup
I have two monitors side by side, with different resolution. The main monitor has the higher resolution, and this is where I usually start the ladder drag.
Unfortunately, it creates this area on top the secondary monitor, over which the cursor jumps, and once it comes back on the monitor, the value has been altered as if it was a functional area of the monitor.. So the value jumps as is the cursor was dragged along the second monitor.
I wonder if there is a way to mitigate the problem..
Edited by AntoineSfx
