Bullet - Increasing Glue Strengths lower Impacts?
catchyid
I did a small experiment to understand the relationship between impacts generated on glue constraints and constraints strength. Below are two results:
Experiment 1 : Glue strength = 20e9 --> max impacts on constraints = 2,879
Experiment 2: Glue strength = 20e1 --> max impacts on constraints = 286,801.8
My question: why impacts are function of Glue strength? As seen above, when I increase Glue Strength I get lower impacts? Should not impact be function of object mass, speed for example and not of glue strength?
PS Attached is a simple hip file for the test...
Thanks
wall_to_destroy_t1.hip
  • 3 months later...
They are not. You are comparing 2 completely different things - in one case constraints are starting to break - which means more free pieces to collide with = more impacts.
Try the same experiment without breaking a single constraint - for example 20e5 vs 20e9. Do u see any difference?
