Link toggle values
philpappas
Inside my hda parameters when a toggle is set to 0 i want another toggle to do the same. where can i write something like an if statement if(toggleA=0) then toggleB=0 else toggleB=chi("../..blah")
i cant do it from the disable when or hide when because that is just for the ui. how can i change the value?
You'll need to use a callback script if you want to actually change the toggle values.
I will say depending on the complexity just disabling/hiding the parameter and in the network or code disabling with a condition should suffice. It's like a magic trick the UI does something different than the actual network.
