RBD doesn't take all geometry only the first one
iam83
You sim is only generating geo on the first frame.
You can set "creation frame" on you rbdPackedObject node to $FF to get it to keep adding more spheres, however, it won't just add the new spheres, it will add a new instance of every sphere on each frame. At Sop level you will need to delete the spheres that have already been added to the sim at each timestep.
Thank you! I'll try that. Sounds complicated though :)
