Houdini Zero Gravity Simulation
MrQozy
Hello.
im trying to simulate a rocket booster with a gas thruster in a vacuum
1- i used a rigid body simulation.
2- turned off gravity.
3- add fan force to move the rocket booster.
how can i make the fan force contentiously follow the same spot it was directed to? ( i want to simulate gas thrusters in space)
the fan force stays in place.
i dont want to animate it, i want it to follow the new booster place using the simulation data.
here is a video
Thank you.
Rocket Zero G.hip
Edited by MrQozy
19 hours ago, anim said:
here is one possible way, you can get the object Position dop data to SOPs compute the fan position and direction and then feed that to the Fan DOP parameters
RocketZeroG_ts.hip
Thank you sooooo much.
you are a life saver.
no one could answer this on reddit and sidefx forums.
again thank you!
