how to read the fourth value in vex
then use array for cost instead of float5
if your cost attribute was float array, then you can use
f@a = f[]@cost[4];
if for some reason you have to keep it float5 then you can sample the value like this for example
float cost[]  = point(0, "cost", @ptnum);
f@a = cost[4];
  • Thanks 1
f@a = f[]@cost[4];
f@a = cost[4];
cool  it works   thanks
