Furox Posted September 26, 2019 Share Posted September 26, 2019 Hi guy! I little question about how to deform a grid with the attribute color... Is a simple question, but i don't know how :O! Thank so much! Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted September 26, 2019 Share Posted September 26, 2019 (edited) By attribute color, you mean a kind of vector displacement ? If you want to do it in SOP context (not at render time), then using a simple Point Wrangle with the following VEX code should do the trick (provided your Cd attribute is a point attribute): @P += @Cd ; If you meant classic displacement of points (along normal - so you need to get normals prior to the Point Wrangle node) with intensity driven by Cd attribute then : @P += @N * len(@Cd) ; Note that len(@Cd) could be replace by only one component of your color attribute (Cd.x for red etc.), or by luminance if you linearly combine each component with proper weights. If you want to do it through texture, then put an Attribute from Map node prior to the above solutions. Last but not least, you can displace at render time, but that’s another story. Edited September 26, 2019 by StepbyStepVFX Quote Link to comment Share on other sites More sharing options...
Furox Posted September 26, 2019 Author Share Posted September 26, 2019 Thank you, for the fast reply! This is working!! But, can i have mush control's on the height, the displacement and the angle of my color? With the attribute transfer, i can do a treshold, but not more.. I will share my scene, but I wish to have more control... AttributeColor.hip Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted September 29, 2019 Share Posted September 29, 2019 Something like this ? AttributeColor-1_v2.hip 1 Quote Link to comment Share on other sites More sharing options...
Furox Posted September 30, 2019 Author Share Posted September 30, 2019 Thank so much!!! This is exactly what i needed :)!!! Quote Link to comment Share on other sites More sharing options...
