Issue with pyro emitted from particles
BlackBaloo
Hi everyone,
I'm trying to create an effect similar to a roman candle (similar to this https://www.youtube.com/watch?v=MVtGNNcTjEE&feature=youtu.be&t=169 )
So I created some particles shooting up, and wanted to emit pyro from it.
Everything works fine but I have an issue I can't fix. When a particle dies, a trail of smoke appears between it's last position and all the others particles.
Someone had the same issue ? I tried all I could think of but did not find a way to fix it.
Thanks
  On 9/26/2019 at 9:53 PM, ejr32123 said:
could you post a photo of the problem?
Expand
Hey Evan,
Thanks for the answer ! A solution was finnaly found in the end
We killed the particles outside of the Pop net (using age and life attributes) so that the Id is not changing within the pop
Thanks a lot *waving at you from my desk just behind you* ;)
