Aniamtion Setup Help
zoki
Hi
here is one file what I would like to do is conect pump handle and bar so they move together-I copied parameter but I can tweak the distance
scroll through playbar and you will see whats the problem
I took a look at the file and you're pretty much there... right now you're referencing the Z rotation of the handle directly and sticking it into the Y translation of the "PumpBar". So you're handle is rotating to 40 degrees and it's sending the PumpBar down 40 units. There's a couple of ways you could change the distance range in the expression: either multiply the expression by a fractional amount and add an offset value to get that PumpBar into the right spot, or (much better) you could wrap your expression in a fit() function, try them both:
for null2's Y translation:
1.78-(.004*ch("../null1/rz"))
or:
fit(ch("../null1/rz"),0,40,1.78,1.62)
Do an "exhelp fit" in the textport for an explanation of the fit() expression... hope this helps!
-JS-
p.s.-if you're doing this for a class assignment then I'm telling your teacher :P
thanks very much exel :D
it is working!
btw its not for school assigment -I will probably have it for my reel though
I was looking to fit function yesterday for some other example from Houdini dvd but I just didnt see both examples as related
anyway tahnks again
zoran
