rendering shops on animated model
tjvoll
I'm animating a ball rolling and i'm using the vex coloured marble shader on it, but even though the ball is rotating (you can see it rotate in wireframe mode), when rendered, the shader renders exactly the same as if the ball isn't even rotating. Can you lock the position of the shader so that it changes according to the position of the geometry?
