Stamping Strings
Is it possible to stamp a string parameter?
In this case I'd like to stamp font names, "file" param of font sop.
I wrote : stamp("../","blah","Courier"), but it looks like stamp function
doesn't eat strings.
Hello.
No, you can't use stamp to return a string. What you might be able to do is to put it into either an Attribute (depending on how you're using this), or use Switch SOP to handle the switching based on your stamp number/IDs. Perhaps that might help?
Thanks for all clues.
I succeeded but in yet different way.
Don't have a clue how to stamp strings using copy sop.
The stamping parameter values doesn't like strings nor string producing expressions.
I don't need it anymore but would like to know how to use it.
Here is a file with random font stamping.
Houdini is so great and powerful, It's easy to create a few hundred dollar titling machine in it :)
peliosis_random_font_02.hipnc
