random Time offset in each instance, redshift instancing
avak
If your walk cycle is written to a .bgeo sequence, you can load the sequence in via a File SOP as a Packed Disk Sequence, and copy that single sequence to every point. From there, you can modify the "index" primitive intrinsic attribute to offset the timing of each copy, using the setprimintrinsic() VEX function.
