particles acceleration limit?
saca
hi
controlling particles by POP_VPO,
subtruct v1 v2
multiply with float
input vector into "v" geometry_vop_global.
i want to accelerate the particles speed.
multiply 0.1, the particles will be slow,
multiply 1.0, the particles will be speedup little bit.
multiply 10000, the particles will be speedup only a little.
whats wrong?
i hope linear acceleration effect to particles.
particles has limitation speed any parameters?
POP speed limit does not used.
thanks.
Sounds like you have conflicting nodes.
Are any force nodes like "POP_WIND" or something like that following this POP_VOP?
If so try pulling these nodes out of the chain, isolate your POP VOP to confirm its the only node acting on your particles and see if the issue persists.
