Merging 2 UV sets to 1
foy
Hey all,
I have a question regarding merging UV sets.
I have an initial object imported into Houdini that was created in Maya and finally exported from Unity with a single UV set. The object was animated by one of our designers in Unity, exported to Houdini to be fractured and RBD simulated. The problem I am running into is  during the UV portion of the process. When I UV the inside faces I end up with an additional UV set.
Is there a recommend workflow to merge UV sets or not create the second UV set altogether? The UV nodes I am using after the material fracture are uvunwrap, uvtransform and finally uvlayout. I am only applying these to the inside group from the material fracture.
Any suggestions would be appreciated.
Mike
Edited by foy
