seiya_kamata Posted October 16, 2019 Share Posted October 16, 2019 (edited) Hi, I need to Scaling packed Objects with According to the height. I want to make the scale smaller as the height increases. Thanks. Edited October 16, 2019 by seiya_kamata Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted October 16, 2019 Share Posted October 16, 2019 In SOP or in DOP ? Do you mean stretching the object (sizex and sizez decrease when sizey increase) or do you mean scattering packed objects on a mountain and have each object smaller when it is higher on the mountain ? Quote Link to comment Share on other sites More sharing options...
seiya_kamata Posted October 16, 2019 Author Share Posted October 16, 2019 (edited) 19 minutes ago, StepbyStepVFX said: SOPまたはDOPで? オブジェクトを引き伸ばすことを意味しますか(サイズが大きくなるとsizexとsizezが減少します)、または山の上にパックされたオブジェクトを散乱させ、山の上にあるときに各オブジェクトを小さくすることを意味しますか? This is test hip data. I want you to go up and get smaller. This Each cube. test_191016.hipnc Edited October 16, 2019 by seiya_kamata Quote Link to comment Share on other sites More sharing options...
