XRM
Hello everyone,
          I was looking at distributed whitewater in houdini. When you click the Particle Fluids -> Distributed Particle Fludis, it creates the necessary nodes needed for clustering whitewater sim. As far as houdini help file, that is what the way is. BUt when I am doing that, it is creating a subnet node inside the whitewater sourcing node named partition_emission. It is throwing an error. There is a node inside it named intersect_box which is a VDB activate node. It has a fit and detail expression. That expression is causing the error. You can see in the screenshots what I am talking about.
Has anyone faced this issue ?
Houdini - 17.5.425.
OS : Ubuntu 19.10
