jordibares Posted November 27, 2019 Share Posted November 27, 2019 I am writing a little python tool that requires evaluating the value of a channel a particular frame, but the object i am evaluating has a chop constraint and the function pos = internal_cam.parmTuple('t').evalAtFrame(f) returns (0,0,0) I imagine the chop network is "overriding" the value but I don't seem to get the result. Any ideas? Thanks. jb Quote Link to comment Share on other sites More sharing options...
symek Posted November 27, 2019 Share Posted November 27, 2019 i think it's not related to constraints nor chops per se. evalParm() is 'conservative' in a sense it doesn't obey higher order operation (as parenting or constraining), just giving raw channel values. Albeit this line: hou.node(...).worldTransformAtTime(frame).extractTranslates() gives the definite position whenever parented, constrained and what's not happening with a node. Quote Link to comment Share on other sites More sharing options...
jordibares Posted November 28, 2019 Author Share Posted November 28, 2019 Thanks Szymon, I did end up using that approach and it works well, nevertheless it has been quite annoying not to be able to rely on the evalAtFrame() I took advantage as well as the worldTransformAtTime does a proper evaluation on the frame so I don't need to update the frame and things are a lot faster and smoother. Thanks once again. Quote Link to comment Share on other sites More sharing options...
