RBD issue when using multiple sopsolver
amaurydo
I use sopsolver to remove soft constraint with the @distance,
With one object everything works (img1/img2) But if I merge the two object, geo explodes before impact (img3/img4)
It's only appens when I uncheck "Attach Internal Constraints to Object" in my Constraint Network to make my sopsolver active, if I don't everything works fine but obviously my soft constraint don't break..
Edited by amaurydo
