Collect Pop Question...
Hi
I've question about collect POP.
I made 1 POP Network and made two source inside it.
then, I make particle motion each sources.
(I checked each particle motions.)
Finally, I collect two sources but, diffrent result what I checked.
Is this a H's bug?
I search the help.... but I can't find any comment about it.
plz help. (my h is 8.0.474)
:lol:
No, no. I mean to try to find out the problem step by step .... one by one, try bypassing various POPs or removing expressions until you can determine what in the pop network is causing the results to be different when you collect them together using the Collect POP.
