Three65 Posted January 27, 2020 Share Posted January 27, 2020 I recently bought the Ivy Taming 1.0 HDA and imported some geometry in to use with it and now that I have my scene set up I am trying to export the ivy as a .OBJ or .FBX and keep getting the error "save failed no such file or directory" I have tried right clicking and saving the geo, using a file node in write mode and even tried a ROP export geometry node. However none of them seem to be writing out the geo I need to import back into C4D. I am thinking that I maybe need to pack or convert the Houdini asset somehow to turn it into geometry that can be exported? Just an idea or maybe I am missing something really simple. If anyone has encountered this error and knows what might be causing it I would appreciate any insight that could be given. Quote Link to comment Share on other sites More sharing options...
Three65 Posted January 28, 2020 Author Share Posted January 28, 2020 I am able to save it out as a .bgeo and re-import it into houdini using a file node. I then tried to save it out from the file node as a .obj and get the same error. Quote Link to comment Share on other sites More sharing options...
acgpepper Posted April 24, 2020 Share Posted April 24, 2020 Had the same problem with the same plugin. The liana exports fine but the stems and leaves are handled differently. Use a convert node to turn them into polys and then you'll be able to export them out. Hope that helps. 1 Quote Link to comment Share on other sites More sharing options...
mars Posted October 4, 2020 Share Posted October 4, 2020 Thank you that suggestion @acgpepper Threw down a convert node and could then save .obj without getting no such file or directory exists issue. Quote Link to comment Share on other sites More sharing options...
