Wire solver angle between hard constraints
stwert
I have a number of wires in a wire solver that I want to connect end to end after simulating for a while (snap together essentially by keying group_broken on), but they are currently joining with a pinched angle, instead of straight on.
1) Does anyone know what determines the angle of the constraint?
  -With some experimentation, it seems it's not determined by the geometry immediately prior to binding, but rather the relative angles of the wires of the initial geometry. I don't want to align the input geometry, but rather change this constraint angle internally.
Image 1 is immediately prior to binding, and image 2 is the bad angled join. If I manually change the input point positions so they're aligned (image 3), then they join straight (image 4).
Any suggestions are appreciated!
Bonus question: With the wire solver, the restlength of the constraint doesn't seem to be respected, it's always 0. Is this a limitation or am I doing something wrong?
