osmeldu Posted February 5, 2020 Share Posted February 5, 2020 Hello. I`m trying to help a friend to setup a command line with redshift and houdini but I havent be able to do it. If I try using mantra, it works like a charm. But if I try with redshift, it dosnt. Looks like the command line is not loading redshift because I receive this errors: "Skipping unrecognized parameter "Redshift_SHOP_parmSwitcher"." " Bad parent found (parent is not a network): shop/rsMat_env_dirt/redshift_material1.init." and more like that. As extra information, if I run the command hconfig in the command line, I receive this: HFS := 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.425' HOME := 'C:/Users/machine' HOUDINI_DESKTOP_DIR := 'C:/Users/machine/Desktop' HOUDINI_OS := 'Windows' HOUDINI_TEMP_DIR := 'C:/Users/machine/AppData/Local/Temp/houdini_temp' HOUDINI_USER_PREF_DIR := 'C:/Users/machine/houdini17.5' HSITE := 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.425/site' USER := 'machine' # but if I run hconfig in the shell from houdini, I get this: HFS := 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.425' HOME := 'C:/Users/machine/Documents;' HOUDINI_DESKTOP_DIR := 'C:/Users/machine/Desktop' HOUDINI_OCL_DEVICENUMBER := 0 HOUDINI_OS := 'Windows' HOUDINI_PATH := 'C:/ProgramData/Redshift/Plugins/Houdini/17.5.425;C:/ProgramData/Redshift/Plugins/Houdini/17.5.425;&;C:/ProgramData/Redshift/Plugins/Houdini/17.5.425;&' HOUDINI_TEMP_DIR := 'C:/Users/machine/AppData/Local/Temp/houdini_temp' HOUDINI_USER_PREF_DIR := 'C:/Users/machine/Documents/houdini17.5' HSITE := 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.425/site' JOB := 'C:/Users/machine' USER := 'machine' # I suspect that hrender cant load redshift because is not loading the enviromen variables. We tried with royal render, and it works with mantra. But it fails with redshift. Rendering with redshift from houdini works perfectly. any help would be appreciate. Thanks Quote Link to comment Share on other sites More sharing options...
