Visual Cortex Lab Posted August 30, 2006 Share Posted August 30, 2006 hi, I'm doing some big geometry "copy" using a POPnetwork sop .. and I'm having a bit of stress with particles number and cook/refresh of my scene. since I'm working on the whole process like... modifying the "to be copied" geometry.... and the geometry that will create the particles as well.. i need the POP to birth less particles sometimes.. just for testing parameters.. and every time I have to enter the POP.. change birth.. exit the POP.. change frame to have the POP make particle birth again ... even "update" button at the top of GUI doesnt force this... if I keep on to the properties window for the sourcePOP. i can change value without entering the POP.. but again.. the only way to make the thing refreshed. is to change frame.. is there any way to FORCE everything to recook from scratch? (or just POP in my case...) cheers. p.s. sorry for posting on both forums.. but...i dont actually know to which give precedence they're both quite cool.. Quote Link to comment Share on other sites More sharing options...
jhiggins Posted October 10, 2006 Share Posted October 10, 2006 have you tried using opcook -F <path to your pop> from a textport window. Quote Link to comment Share on other sites More sharing options...
Visual Cortex Lab Posted October 10, 2006 Author Share Posted October 10, 2006 hey.... nope.. never tried before... but i immediately did .. and seams not working here... i'm now using the "bypass flag" method since I had this needs to recook pop networks..... thanks for the trick anyway .. I'll might try in different scenario .. cheers Quote Link to comment Share on other sites More sharing options...
jhiggins Posted October 19, 2006 Share Posted October 19, 2006 [one' date=Oct 10 2006, 03:40 PM' post='31284]thanks for the trick anyway .. I'll might try in different scenario .. no prob Quote Link to comment Share on other sites More sharing options...
