Memory Leak / Purge Memory Command?
I am trying to render some heavy geometry via the geometry ROP. On any single frame, it works well, however If I try to render the ROP as a range (240 frames) is dies about 30 frams with an out of memory error. houdini itself is taking 1400 mb. I am running xp64 which should have the 3G limit, so I would expect a bit more ceiling on a 32bit app.
The bgeos themselves that I am writing are only 10mb/frame, but it is full of nurbs surfaces.
Is there a command to clear the SOP cache that I could put in the pre-frame script?
I think it would also work if I were to make a script that repeatadly opens the hip file, renders a frame and closes it, but I am a bit unsure how to go about this. I have not found a definitive answer as to how to run houdini from the DOS commandline, and render a single specific frame. If I knew that I could use our renderfarm manager to queue the frames.
THanks for any help
MD
whoops, just found sopcache -c, testing it now, so far so good...
MD
UPDATE, naw it's f'ed. It does creep up slower, but you still have to quit houdini to release the RAM.
Now I am trying to get the command line to work.
THanks for any help
MD
