copy to points with little bit off from pivot
I'm trying to copy geometries to points with target points orientation randomized.
But it's a little bit off. Unchecking Transform Using Target Point Orientations in copytopoints node copies to the points, but without orientation.
These target points are not static. It is simulated but I've used timeshift node to the targeted frame. Both start and end frame clamped.
Before coping geometries to points, I added an pointwrangle to randomize orientation for taget points.
Quote
VEX I used for points orientation
@orient = rand(@ptnum);
Thank you as always for your help :)
Image and hip files are posted below.
HIP file : flares_odforce_0327.hip
Your source for the points to copy are from an RBD simulation, so they have a v@pivot point attribute, which the Copy to Points SOP recognizes and will apply to the resulting geometry. If you just delete v@pivot, you'll get your copies centered on the input points.
  • Thanks 1
Thanks :) It's now copied to the input points !
