Shyralon Posted March 30, 2020 Share Posted March 30, 2020 Hello! I built a little tool to help our layout which essentially places the correct asset from a library on scattered points. For this I use the instance node with a point attribute to place the correct .FBX. Now I would instead like to make use of arnold proxies exportet as .ass file but could not found any information on how to instance those instead. Any ideas? could I still simply use the instance node or is this more complex? Quote Link to comment Share on other sites More sharing options...
Verville_Pierluc Posted March 31, 2020 Share Posted March 31, 2020 Hi Ramon! Have you check the documentation of HTOA? You should have everything you need in there. https://docs.arnoldrenderer.com/display/A5AFHUG/Instancing Thanks Quote Link to comment Share on other sites More sharing options...
Shyralon Posted April 4, 2020 Author Share Posted April 4, 2020 Hey, thank you very much for your answer! Must have missed that page, looks exactly like the thing I was looking for. Quote Link to comment Share on other sites More sharing options...
