Dust
kingsoz
hi people!!
wondering if somebody could help me here or just gimme a pointer into the right directions...
i'm tryin to make a horse run through a dirt track, and want some dust to spring up as it runs and it blow away to one side realistically.
i've been messing around for a while with many settings, but just cant get it right. anybody done this before or seen it around so i could take a look at??
any help would be greatly appreciated!
thanks
king soz
I would check out the Noise Tab under the Force POP. Basically you would probably want 2 Force pops one with a high frequency/low amp, and the other with a low frequency/high amp. Play with those parameters and it should start pointing you in the right direction. Then control your alpha using a Color POP based on $LIFE
