Threadripper 3970x Clock Speeds
Hans Peter
Hi, to all of you who own the 3970x: how the hell is amd doing ist single core boost? So the all core stock Clock should be at arount 3.7 GHZ, the single core bost way beyong 4, around 4.5 GHZ? When I check the Clock Speeds with Multi threadding Tasks I can see the Clocks stick to 3.7. Unfortunately the cpu does the same in single core unsage...stuck to 3.7, no boost at all. Now when I run the AMD Ryzen Master tool its pushing the single core Speed but the multithread Clocks as well - what makes the cpu too hot Overall.
