TheUsualAlex Posted September 17, 2006 Share Posted September 17, 2006 Hello, Does anyone know of a function/module/keyword that would allow me to trap output resulted from system calls? os.system() only returns success/failure. I think it's called globbing? Not sure... Thanks! Quote Link to comment Share on other sites More sharing options...
sibarrick Posted September 17, 2006 Share Posted September 17, 2006 Is this a python question? ie myVar = os.system(blah) And the result is 0 or 1 but the function called does a whole heap of stuff? I think you are stuck you really need a function that will return a string then you can grab that. Might be wrong though. What function are you actually trying to call? Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted September 17, 2006 Share Posted September 17, 2006 Capturing the output of a subprocess is not called globbing. Globbing is a method for string matching using '*' and '?'. This is often used in the shell, so that globbing often refers to the matching of file names. Capturing the output of an executable is done easily with Popen instead of os.system. Take a look at the following example, that calls ls -lh and afterwards prints the result line by line: from subprocess import Popen, PIPE, STDOUT process = Popen(('ls', '-lh'), stdout=PIPE, stderr=STDOUT) for line in process.stdout: print line On the other side, if you only want a list of files (globbing), you can use the glob module import os, glob searchDir = "." listOfFiles = glob.glob(os.path.join(searchDir,"*.*")) for f in listOfFiles: print f Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted September 17, 2006 Author Share Posted September 17, 2006 Wow! Thanks Frank! That was exactly what I was looking for. It never occured to me to look into the subprocess module -- it's making a bit more sense now. Thanks for clearifying the term "globbing" also. I got confused with this term from back when I was learning Perl several years back. Hi Simon, I was just trying to call the Cygwin program (cygpath) to retrieve correctly formatted path. cygpath will spit a line of string to stdout (assuming no error). Though os.system() will do the correct thing, but it won't capture what was spitted out from cygpath. In perl it's the same as doing `` to capture that stdout. Thanks again! Quote Link to comment Share on other sites More sharing options...
