Sblend Object Morph Flickering Geometry
Hi, I’m morphing between two vdb objects using an sblend node. My node set up is File->VDB from Polygons->Sblend. I'm animating the sblend to morph from Obj 1 to Obj 2 over time. While Obj 1 is morphing to Obj 2 there is a ton of flickering geometry where the objects do not overlap. I'm hoping there is a way to be able to blend between two objects seamlessly without having to have them overlap perfectly.
I've attached a visual example of what's happening along with my hip file. Any help would be much appreciated!
ObjMorphTest.mov
Object Morph Test.hiplc
