rendertimes Posted April 12, 2020 Share Posted April 12, 2020 Hi, I’m morphing between two vdb objects using an sblend node. My node set up is File->VDB from Polygons->Sblend. I'm animating the sblend to morph from Obj 1 to Obj 2 over time. While Obj 1 is morphing to Obj 2 there is a ton of flickering geometry where the objects do not overlap. I'm hoping there is a way to be able to blend between two objects seamlessly without having to have them overlap perfectly. I've attached a visual example of what's happening along with my hip file. Any help would be much appreciated! ObjMorphTest.mov Object Morph Test.hiplc Quote Link to comment Share on other sites More sharing options...
