Way to reference a channel but at a different time (like ValueAtTime in AE)?
bentway23
Is there a way, when doing a channel reference, to point to the referenced channel but at a different time than the current $T, a la After Effects' ValueAtTime expression?
In some situations I understand throwing a time shift to create another stream of the referenced object might work, but that won't work on the setup I have going, where a null parameter has a five-keyframe movement that I want to drive properties of two different objects, one four frames after the first. Because there are so few frames this is an easy one to simply duplicate any time I have to change it, but it seems like there should be a more procedural way.
