gangland Posted April 17, 2020 Share Posted April 17, 2020 Hello guys, i need to apply the surface tension only in a slice of the container. I using the Gas Surface Tension SOP and i'm noticed that has a field called Mask Field! i put an test geometry to use as mask but with no luck at all, isn't working properly. how is supossed to work it properly? thanks in advance, cheers ps: im attaching an simple hip exemple. gas_maskfield_v000.hip Quote Link to comment Share on other sites More sharing options...
thebrettwalter Posted April 18, 2020 Share Posted April 18, 2020 does this help? exoskeleton_gas_maskfield_v000.hipnc Quote Link to comment Share on other sites More sharing options...
